修复你的物品
维修的权力
配件 & 工具
MacBook Santa Rosa/Penryn Fan
  • MacBook Santa Rosa/Penryn Fan
US$29.99
US$29.99
当产品有货时,我们将给你发送消息。
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
产品详细说明
描述
描述
Replacing a broken or noisy fan?
Includes fan and surrounding metal bracket.
兼容性
兼容性
  • 2.0 (Santa Rosa) or 2.2 GHz Core 2 Duo MacBooks
  • 2.1 or 2.4 GHz Core 2 Duo MacBooks
  • 2.0 GHz (Early 2009) Core 2 Duo MacBooks
  • 2.13 GHz (Mid 2009) Core 2 Duo MacBooks
产品规格
产品规格
Part #:
922-8273
兼容性
MacBook Core 2 Duo
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
维修的故事
用户头像
我的问题
My daughter's Mac sounded like a lawnmower when it got hot.
我的修理方法
Repair was relatively straightforward following the guide on iFixit.
我的建议
Some of the steps refer to a #0 Philips but a smaller screwdriver works better. Watch out for the screws behind the memory cover. When replacing, use light pressure to get t . . .
用户头像
我的问题
My hard drive finally went up after 8 years. When I opened up my Mac to clean out dust, I noticed my fan seemed off... Considering it went from loud to silent overnight. I tested it and it was also in need of replacement, so I ordered the part.
我的修理方法
Easy as pie. The guide is 100% accurate and the screws a . . .
用户头像
我的问题
La ventola, oltre a essere rumorosa, iniziava a perdere giri e le temperature salivano troppo; dopo anni di servizio era arrivata al capolinea.
我的修理方法
Dopo la sostituzione il computer è tornato silenzioso e le temperature sono nuovamente sotto controllo.
La prima ventola che mi hanno spedito si è rivelata . . .
用户头像
我的问题
LAPTOP OVER HEATING AND SHUTTING DOWN, fan not blowing
我的修理方法
I ordered part from Ifixit. I had previously replaced my keypad with new one from IFIXIT and directions I found on youtube. So I had and idea on how to disassemble. I took my laptop to a computer repair store, he said not busy at all. Big mistak . . .
用户头像
我的问题
The fan in my 2009 Macbook broke down; we went to iCentre here in The Netherlands who claimed the main board broke down; yes, for EUR 1100,- we could replace it. AND .. they had a nice action right that moment for a new Macbook Pro blah blah blah…
Ofcourse we did not go for their stories and w . . .
用户头像
我的问题
My MacBook Santa Rosa was heating and the noise of the fan was too loud.
我的修理方法
I've change thermal paste and fan with a new one. The fan replacement wasn't necessary, the old one was in good shape. The thermal paste replacement has reduced the heating.
我的建议
Do not replace the fan heaven if you think your MacBook . . .
用户头像
我的问题
So the problem was not even the fan, it was the inverter, SO while changing the inverter i thought it would be a good idea to clean out the dust in the fan and under the board. Turns out an air compressor at max speed will destroy a macbook fan, so while i was fixing one thing, i broke another, So i . . .
用户头像
我的问题
making a loud noise
我的修理方法
followed the instructions on the guide and it was very straightforward
我的建议
I taped each set of screws onto a piece of printer paper and labeled them as i went, which made them easy to keep track of.
显示更多
