产品详细说明
描述
This MacBook Pro 17" Unibody (Early 2009-Mid 2010) replacement battery is what you need to bring your dead laptop back to life!
- 100% factory tested.
- Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 12530 mAh.
- Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
- Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your MacBook Pro's lifespan, extend it with this replacement battery compatible with MacBook Pro 17" Unibody (Early 2009-Mid 2010). Factory-installed MacBook Pro 17" Unibody (Early 2009-Mid 2010) batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
套装内容
- MacBook Pro 17" Unibody (Early 2009-Mid 2010) Replacement Battery
- Spudger
- iFixit Precision Bit Driver
- Precision 4 mm Bits:
- Pentalobe P6
- Phillips #00
- Tri-point Y0
兼容性
- MacBook Pro 17" Unibody A1297 Early 2009 to Mid 2010
产品规格
兼容性
客户评价
