MacBook Pro 16" 2019 Case Components
Grab a toolkit for your MacBook Pro 16" 2019 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 16" (2019) Upper Case Assembly
Replace an upper case, keyboard, and battery compatible with the 2019 model A2141 MacBook Pro 16 inch laptop.
MacBook Pro 16" (2019) Heat Sink Brackets
Replace the metal spring brackets that press the heat sink against the CPU.
MacBook Pro 16" (2019) Touch Bar Cable Brackets
Replace a bent or missing bracket securing the touch bar cable connector 2019 model 16" MacBook Pro laptop.
MacBook Pro 16" (2019) Touch ID Sensor Cable Bracket
Replace a bent or missing bracket securing the touch ID sensor cable connector in a 2019 model 16" MacBook Pro laptop.
MacBook Pro 16" (2019) USB-C Cable Brackets
Replace a bent or missing bracket securing a USB-C cable connector to the logic board in a 2019 model 16" MacBook Pro laptop.
MacBook Pro 16" (2019) Display Cable Brackets
Replace a bent or missing bracket securing the display cable to the logic board and case in a 2019 model 16" MacBook Pro laptop.
MacBook Pro 16" (2019) Headphone Jack Cable Bracket
Replace a bent or missing bracket securing the headphone jack cable to the logic board in a 2019 model 16" MacBook Pro laptop.
MacBook Pro 16" (2019) Trackpad Cable Bracket
Replace a bent or missing bracket securing the trackpad cable to the logic board in a 2019 model 16" MacBook Pro laptop.
MacBook Pro 16" (2019) Display Hinge Covers
Replace a damaged or missing plastic cover for the display hinges in a 2019 model 16" MacBook Pro laptop.
MacBook Pro 16" (2019) Lower Case
Replace a scratched or dented lower case compatible with a 2019 model 16" MacBook Pro.
电子设备简介
Introduced in November 2019 as model A2141, this MacBook Pro features Coffee Lake processors up to the 2.4 GHz Intel Core i9 processor with Turbo Boost up to 5.0 GHz.
The most common repairs with the 16" MacBook Pro 2019 laptops are replacing a dead battery, replacing a malfunctioning fan, or a damaged display assembly.
The battery in a MacBook Pro 16" 2019 is adhered to the inside of the upper case. Our replacement batteries include the needed adhesive.
The MacBook Pro 16" 2019 models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 16" 2019 repair guides for step-by-step instructions on how to make the fix.
