修复你的物品
维修的权力
商店
MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly
  • MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly
US$149.99
US$149.99
产品详细说明
描述
描述
This Early 2011-Late 2011 MacBook Pro 15" Unibody replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
Replace a broken front glass or malfunctioning LCD display on your laptop. This screen assembly will renew the appearance of your front panel and eliminate the flickering on an aging display.
零件包括
零件包括
  • 15.4" LCD screen
  • Display Cover
  • Bezel
  • FaceTime HD Camera
  • Clutch Hinges
  • Wi-Fi Antenna
  • Camera
  • Display Data Cables
兼容性
兼容性
  • MacBook Pro 15" Unibody A1286 Early 2011 to Late 2011
产品规格
产品规格
Part #:
661-5847
Diagonal Size:
15.4"
兼容性
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
维修的故事
用户头像
我的问题
Bought a macbook pro as a refurbished device with a Matt screen, and the colors where washed out.
我的修理方法
Pretty easy
我的建议
When putting the new screen in the alignment for the hinges are a little bit tricky just some patience and you'll be golden
用户头像
我的问题
Screen glass, display and top cover damaged due hard object dropping onto my wife's computer when in closed position.
我的修理方法
Repair went OK until having to remove cable display data cable retainer from the upper case. The retaining screw could not be removed however hard I tried - the result being that th . . .
