产品详细说明
描述
This MacBook Pro 15" Retina (Mid 2018-2019) replacement battery fix kit includes all the parts, tools, and adhesive you need to bring your dead laptop back to life!
- 100% factory tested.
- Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 7336 mAh.
- Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
- Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop's lifespan, extend it with this new replacement battery compatible with Mid 2018 to 2019 MacBook Pro 15" Retina. Factory-installed MacBook Pro batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
零件包括
- New replacement battery compatible with a MacBook Pro 15" Retina (Mid 2018/2019)
- Installation adhesive
套装内容
- iFixit Adhesive Remover
- Safety Glasses
- Nitrile Gloves (2)
- Berkshire PRO Wipe 880
- Suction Handle
- Spudger
- Plastic Cards (2)
- iFixit Opening Tool
- iFixit Opening Picks (Set of 6)
- Angled Tweezers
- Precision Bit Driver
- 4 mm Precision Bits:
- Pentalobe P2
- Pentalobe P5
- Torx T3
- Torx T5
- Torx Security TR8
兼容性
- MacBook Pro 15" Retina A1990 Mid 2018 to 2019
产品规格
兼容性
客户评价
