修复你的物品
维修的权力
商店
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
  • MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery / New / Fix Kit
  • MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery / New / Part Only
  • 360°
360
US$99.99
US$99.99
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
产品详细说明
描述
描述
This MacBook Pro 15" Retina (Mid 2012-Early 2013) replacement battery fix kit includes all the parts, tools, and adhesive you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 8250 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop's lifespan, extend it with this new replacement battery compatible with Mid 2012 to Early 2013 MacBook Pro 15" Retina . Factory-installed MacBook Pro batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
套装内容
套装内容
兼容性
兼容性
  • MacBook Pro 15" Retina A1398 Mid 2012 to Early 2013
产品规格
产品规格
Model #:
A1417
Watt Hours:
95 Wh
Voltage:
10.95 V
Milliamp Hours:
8460 mAh
Manufacturer:
Aftermarket
兼容性
MacBook Pro 15" Retina Display Early 2013
A1398 (EMC 2673) 2.4 GHz
A1398 (EMC 2673) 2.7 GHz
A1398 (EMC 2673) 2.8 GHz
MacBook Pro 15" Retina Display Mid 2012
A1398 (EMC 2512) 2.3 GHz
A1398 (EMC 2512) 2.6 GHz
A1398 (EMC 2512) 2.7 GHz
客户评价
