修复你的物品
维修的权力
商店
MacBook Pro 15" (Model A1211) Left I/O Board
  • MacBook Pro 15" (Model A1211) Left I/O Board
  • 360°
360
US$29.99
US$29.99
产品详细说明
描述
描述
Replace a damaged or corroded I/O board for your model A1211 MacBook Pro 15" and fix problems with charging, audio, and data connections.
  • Includes the MagSafe power, USB, and audio ports.
  • Includes slots for internal Airport wireless card and PC Card ExpressCards.
兼容性
兼容性
  • MacBook Pro 15" A1211
产品规格
产品规格
Part #:
922-7911, 820-2055-A
兼容性
MacBook Pro 15" Core 2 Duo Model A1211
A1211 (EMC 2120) 2.16 GHz
A1211 (EMC 2120) 2.33 GHz
维修的故事
用户头像
我的问题
Old Macbook Pro, no longer charging. I thought this laptop was consigned to the bin as the repair would have cost hundreds (at least that's what I thought!)
我的修理方法
It went surprisingly well and with very little collateral damage to other systems
我的建议
1) Make sure you've got lots of space
2) Make sure that space i . . .
用户头像
我的问题
Working on my 2006 MBP , computer suddenly shut down, no warning of low battery, nothing. I immediately plugged in the charger, and noticed that the mag. plug did not / would not change to the orange charging state. I then checked the battery, ¾ charged. I managed to get the MBP laptop running . . .
用户头像
我的问题
A friend of mine dropped her macbook pro while it was charging and the magnet jack broke. She took it to an apple store to see about repairs, but out of warranty she was quoted 500$+ to repair it. She has 4 kids and is a single mom she could not afford the repairs or a new laptop, since I have exp . . .
用户头像
我的问题
Went to plug in the magsafe adapter into the MBP and got a juicy static electric discharge at the connector. Battery would not charge even though it continued to work off the power it was supplying. Tried another battery and had the same problem. My fear was correct in assuming the Left i/o board wa . . .
用户头像
我的问题
IO Board broke because pB dropped on the magsafe plug ;; ripped the connecters of the IO Board & blew some circuit.
我的修理方法
Part arrived before promised ship date; with the on-line guide replaced the board; reset PRAM and SMC and all is fine again. Very smooth dealing with Ifixit ... kudos' !!
我的建议
no as difficult . . .
用户头像
我的问题
For years I've had a chronic problem with battery charging on a MacBook Pro. The laptop would indicate significant battery life remaining, yet discharge too rapidly and at some point abruptly crash as though all power was removed. Eventually, the battery would not charge at all and the laptop would . . .
用户头像
我的问题
My computer was not charging. The power cord would short out due to a bad connection at the Left I/O Board. The cause of the problem started years ago when my daughter decided to chew on the end of the power cord causing corrosion and subsequently shorting between the power cord and Left I/O Board c . . .
显示更多
