配件 Mac MacBook Pro 15" Unibody Hard Drives SATA
商店
不知道你的型号吗? 识别你的 Mac
MacBook and MacBook Pro Unibody Plastic Feet / Part Only
Replace the black plastic feet on the lower case of your Unibody MacBook or MacBook Pro.
来自US$4.99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8.99
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery / New / Fix Kit
Replacement battery, compatible with all Early 2011, Late 2011, and Mid 2012 15" Unibody MacBook Pros.
来自US$84.99
Macbook Pro Unibody Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
来自US$9.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7.99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
来自US$89.99
MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Replacement Battery / Fix Kit
Replace the battery for the Mid 2009/Mid 2010 MacBook Pro 15"
来自US$84.99
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector.
来自US$14.99
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard and internal power button switch compatible with a Unibody A1286 15" MacBook Pro from mid 2009 to mid 2012.
US$19.99
PC3L-12800 8 GB RAM Chip
RAM / 8 GB / PC3L-12800 / Low Profile / 204 pin, 1600 MHz
来自US$49.99
显示产品 1-10 / 131
电子设备简介
In October of 2008 Apple released the MacBook Pro 15" Unibody with an aluminum case drilled from a single aluminum brick. With the exception of the 2.53 GHz Mid 2009 model, all 15" Unibody models feature 2 graphics cards, one for power saving casual use and one for graphics-intensive processing.
The most common repairs with the MacBook Pro 15" Unibody models are replacing a dead battery, upgrading the hard drive, or upgrading the RAM. Choose a model for more specific information.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody MacBook Pro 15" Unibody Repair for step-by-step instructions on how to make the fix.
