MacBook Pro 15" Unibody Early 2011 Case Components
Grab a toolkit for your MacBook Pro 15" Unibody Early 2011 model and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a scratched or malfunctioning trackpad.
MacBook Pro 15" Unibody (Mid 2010-Mid 2012) Lower Case
Replace a broken or damaged lower case for your Mid 2010 to Mid 2012 MacBook Pro 15" Unibody with this part. This part includes 4 rubber feet.
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Bracket
This bracket houses the Airport/Bluetooth board.
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
Replace a broken or damaged upper case compatible with your Early 2011 to Mid 2012 15" MacBook Pro Unibody with this part. This assembly includes backlit keyboard and bat...
MacBook Pro Unibody (Mid 2009-Mid 2012) Trackpad Mounting Screws
Replacement screws and springs for mounting the trackpad in the upper case assembly of mid 2009 through mid 2012, 13" and 15" MacBook Pro Unibody laptops.
电子设备简介
The Early 2011 version of MacBook Pro 15" Unibody features an upgraded graphics chip and a new quad core Core i7 processor with PC3-10600 RAM. The Mini DisplayPort was also replaced (but still backwards compatible) with the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The most common repairs with Early 2011 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (Early 2011) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
The Early 2011 model MacBook Pro 15" Unibody requires a Tri-point Y0 Screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody Early 2011 repair guides for step-by-step instructions on how to make the fix.
