配件 Mac MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Rubber Feet
商店
Grab a MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Fix Kit and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
不知道你的型号吗? 识别你的 Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8.99
Macbook Pro Unibody Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
来自US$9.99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
来自US$89.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7.99
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector.
来自US$14.99
MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Replacement Battery / Fix Kit
Replace the battery for the Mid 2009/Mid 2010 MacBook Pro 15"
来自US$89.99
PC3-8500 4 GB RAM Chip
Replace or upgrade the RAM in your desktop, laptop, or game console for faster performance. Low Profile / 204 pin / 1066 MHz
US$29.99
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard and internal power button switch compatible with a Unibody A1286 15" MacBook Pro from mid 2009 to mid 2012.
US$19.99
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a scratched or malfunctioning trackpad.
来自US$24.99
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
US$9.99
显示产品 1-10 / 46
电子设备简介
The 2.53 GHz Mid 2009 version of the MacBook Pro 15" Unibody shares more in common with the MBP 13" Unibody than other MBP 15" Unibody models. The 2.53 GHz machine features a single fan and graphics chip with shared memory.
The most common repairs with 2.53 GHz Mid 2009 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (2.53 GHz Mid 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
The 2.53 GHz Mid 2009 model MacBook Pro 15" Unibody requires a P6 Pentalobe screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody 2.53 GHz Mid 2009 repair guides for step-by-step instructions on how to make the fix.
