修复你的物品
维修的权力
商店
Parts Mac MacBook Pro MacBook Pro 15" MacBook Pro 15" Retina Case Components
商店
Grab a toolkit for your MacBook Pro 15" Retina model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
不知道你的型号吗? 识别你的 Mac
MacBook Pro 15" Retina (Mid 2012-Early 2013) Trackpad / New / With Cable
Replace a trackpad compatible with the mid 2012 or early 2013 model A1398 MacBook Pro 15 inch Retina laptop. Part #661-8311, 661-6532.
来自US$39.99
MacBook Pro 15" Retina (Late 2016-2017) Upper Case / A-Stock / Dark Gray
Replace a scratched or dented upper case or malfunctioning keyboard compatible with a 2016 or 2017 model 15" MacBook Pro with Retina Display.
来自US$127.99
MacBook Pro 15" Retina (Late 2013-Mid 2015) Lower Case
Replace a scratched or dented lower case compatible with a Late 2013 to Mid 2015 MacBook Pro 15" Retina laptop.
来自US$49.99
MacBook Pro 15" Retina (Late 2016-2019) Lower Case / New / Dark Gray
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
来自US$95.99
MacBook Pro 15" Retina (Mid 2015) Upper Case Assembly / A-Stock / With Trackpad and Battery
Replace an upper case assembly compatible with the Mid 2015 MacBook Pro 15" Retina laptop.
来自US$105.99
MacBook Pro 15" Retina (Late 2013-Mid 2014) Upper Case Assembly / A-Stock / With Trackpad, Without Battery
Replace an upper case assembly compatible with the MacBook Pro 15 inch Retina Late 2013 to Mid 2014 model A1398. Part #661-8311.
来自US$119.99
MacBook Pro 15" Retina (Mid 2012-Early 2013) Upper Case Assembly / A-Stock / No Trackpad or Battery
Replace an upper case and keyboard compatible with the Mid 2012 to Early 2013 Retina 14" MacBook Pro laptop.
US$199.99
MacBook Pro 15" Retina (Late 2016-2019) Trackpad / New / Dark Gray
Replace a damaged or malfunctioning trackpad compatible with a Late 2016 to 2019 model MacBook Pro 15" with Retina Display and Touch Bar.
来自US$59.99
MacBook Pro 15" Retina (Late 2016-2017) Display Gasket
Replace the elastic plastic gasket that fits around the outside edge of the display assembly for a Late 2016 or 2017 model 15" MacBook Pro with Retina Display.
US$9.99
MacBook Pro 15" Retina (Late 2016/2017) Display Lower Edge Bezel Bracket
Replace a bent or damaged metal bracket that backs up the bezel at the bottom edge of the display assembly in a Late 2017 or 2017 model 15" MacBook Pro with Retina disp...
US$12.99
显示产品 1-10 / 26
电子设备简介
In June 2012 Apple released the MacBook Pro 15" with a new Retina display with a 2880-by-1800 resolution. The Retina display models that followed the 2012 model vary by specifications and features.
The most common repairs with the 15" MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly. Choose a model for more specific information.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display repair guides for step-by-step instructions on how to make the fix.
