MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
  • MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
  • 360°
360
US$209.99
US$209.99
产品详细说明
描述
描述
Replace the 2.4 GHz logic board in your MacBook Pro 13" Unibody (Mid 2010) laptop and fix processing issues.
  • Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot.
A corroded, malfunctioning, or water-damaged logic board can cause unexpected shutdowns or reboots. Restore the functionality of your device with this replacement part.
兼容性
兼容性
  • MacBook Pro 13" Unibody A1278 Mid 2010
产品规格
产品规格
Part #:
661-5559
Model #:
A1278
Speed:
2.4 GHz
GPU:
NVIDIA GeForce 320M
兼容性
MacBook Pro 13" Unibody Mid 2010
A1278 (EMC 2351) 2.4 GHz
A1278 (EMC 2351) 2.66 GHz
维修的故事
用户头像
我的问题
My MacBook Pro was suffering from the same Graphics problem as many others have experienced.
我的修理方法
I followed the instructions to take out the faulty Logic Board. Then I installed the replacement from iFixIt, with a little bit of thermal paste. Got it all screwed back together and was done in 25 Minutes. . . .
用户头像
我的问题
The logic board failed due to my daughter spilling milk on it. I tried to clean the board but the lactic acid managed to eat away some of the thin traces.
我的修理方法
I ordered a replacement from iFixIt, removed the old board and installed the new one. The system booted and everything worked as expected. So f . . .
用户头像
我的问题
My computer’s logic board stopped working, needed to be replaced.
我的修理方法
The repair was actually pretty easy and I felt proud of myself for the repair... and thankful for iFix :)
我的建议
Always be curious (but cautious)! There’s so many things you can do on your own and save money if you take the time to researc . . .
用户头像
我的问题
Broken RAM sloth, so the MacBook was working a bit slow.
我的修理方法
It went very well. The guide I used was very helpful and made the repair very easy! :)
我的建议
If you just follow the guide everything goes smoothly! :)
用户头像
我的问题
A few weeks ago my Macbook Pro started malfunctioning and gave me a blank white screen with a flashing folder and a question mark. I was unsure what this was and after some online research I figured it may be my hard drive. I installed a new hard drive but my Mac wouldn’t see it after going into r . . .
用户头像
我的问题
One drop or water got to the logic board
我的修理方法
simple replacement
我的建议
keep Mac away from ANY source of moisture
显示更多
