修复你的物品
维修的权力
商店
Parts Mac MacBook Pro MacBook Pro 13" Heat Sinks
商店
Grab a toolkit for your MacBook Pro 13" model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
不知道你的型号吗? 识别你的 Mac
MacBook Pro 13" Unibody (Mid 2012) Heat Sink
Replace a bent or damaged heat sink compatible with a mid 2012 model 13" MacBook Pro Unibody laptop.
来自US$4.99
MacBook Pro 13" Unibody (Mid 2010) Heat Sink
This part attaches to the processor and helps dissipate heat.
US$8.99
MacBook Pro 13" Unibody (Early 2011-Late 2011) Heat Sink
US$17.99
MacBook Pro 13" Retina (Late 2013-Early 2015) Heat Sink
Replace a damaged heat sink. This part dissipates heat generated by your computer's processors.
US$31.99
MacBook Air 13" and MacBook Pro 13" (A2337, A2338, Late 2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a late 2020 model A2337 or A2338 13" MacBook Air or MacBook Pro laptop.
US$9.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Heat Sink / New
Replace a damaged heat sink compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar. The heat sink dissipates heat from the CPU.
来自US$39.99
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Heat Sink / Used
Replace a damaged heat sink in a 2016 or 2017 model 13" MacBook Pro with Retina Display and function keys.
来自US$19.99
MacBook Pro 13" Retina (Late 2016-2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2020 model 13" MacBook Pro with Retina Display.
US$5.99
MacBook Pro 13" (A2251, 2020) Heat Sink
Replace a damaged heat sink compatible with a 2020 model A2251 13" MacBook Pro laptop. The heat sink dissipates heat from the CPU.
US$24.99
MacBook Pro 13" (A2289, 2020) Heat Sink
Replace a damaged heat sink compatible with a 2020 model A2289 13" MacBook Pro with two Thunderbolt Ports. The heat sink dissipates heat from the CPU.
US$49.99
显示产品 1-10 / 14
电子设备简介
Catering to the working professional, the MacBook Pro 13" is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
Select your version above for parts and assistance!
