配件 Mac MacBook Pro 13" Unibody Headphone Jacks
商店
不知道你的型号吗? 识别你的 Mac
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Replacement Battery / Fix Kit
Replace a dead or dying battery compatible with a 13" Unibody MacBook Pro laptop.
来自US$99.99
MacBook and MacBook Pro Unibody Plastic Feet / Part Only
Replace the black plastic feet on the lower case of your Unibody MacBook or MacBook Pro.
来自US$4.99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8.99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
来自US$89.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7.99
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable / With Bracket / New
This cable connects the hard drive to the logic board.
来自US$34.99
Macbook Pro Unibody Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
来自US$9.99
MacBook Pro Unibody (A1278) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard and power button switch compatible with a mid 2009 to mid 2012 A1278 model 13" MacBook Pro Unibody laptop.
US$19.99
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector.
来自US$14.99
PC3L-12800 8 GB RAM Chip
RAM / 8 GB / PC3L-12800 / Low Profile / 204 pin, 1600 MHz
来自US$49.99
显示产品 1-10 / 85
电子设备简介
With the Mid 2009 model 13 inch MacBook Pro Unibody laptop, Apple brought back the Firewire 800 port, and added an SD card slot. The 13" Unibody models continued through Mid 2012.
The most common repairs with the MacBook Pro 13" Unibody models are replacing a dead battery or upgrading the hard drive or RAM. Choose a model for more specific information.
The MacBook Pro 13" Unibody models require a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody repair guides for step-by-step instructions on how to make the fix.
