配件 Mac MacBook Pro 13" Unibody Mid 2009 Heat Sinks
商店
不知道你的型号吗? 识别你的 Mac 笔记本
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Replacement Battery / Fix Kit
Replace a dead or dying battery compatible with a 13" Unibody MacBook Pro laptop.
来自US$84.99
MacBook and MacBook Pro Unibody Plastic Feet / Part Only
Replace the black plastic feet on the lower case of your Unibody MacBook or MacBook Pro.
来自US$4.99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7.99
Macbook Pro Unibody Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
来自US$9.99
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector.
来自US$14.99
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a scratched or malfunctioning trackpad in your 13” Unibody MacBook Pro.
来自US$59.99
MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / New / Black
Replace a malfunctioning or noisy fan compatible with several models of 13" MacBook and MacBook Pro Unibody laptops.
来自US$8.99
PC3-8500 4 GB RAM Chip
Replace or upgrade the RAM in your desktop, laptop, or game console for faster performance. Low Profile / 204 pin / 1066 MHz
US$39.99
MacBook Pro Unibody (A1278) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard and power button switch compatible with a mid 2009 to mid 2012 A1278 model 13" MacBook Pro Unibody laptop.
US$19.99
显示产品 1-10 / 51
电子设备简介
With the Mid 2009 model 13 inch MacBook Pro Unibody laptop, Apple brought back the Firewire 800 port, added an SD card slot, and increased the processor speed.
The most common repairs with the MacBook Pro 13" Unibody for Mid 2009 are replacing a dead battery or upgrading the hard drive or RAM. The MacBook Pro 13" Unibody (Mid 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
The MacBook Pro 13" Unibody for Mid 2009 requires a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody for Mid 2009 repair guides for step-by-step instructions on how to make the fix.
