修复你的物品
维修的权力
商店
Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Two Thunderbolt Ports 2019 Case Components
商店
Grab a toolkit for your MacBook Pro 13" Two Thunderbolt Ports 2019 model and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
不知道你的型号吗? 识别你的 Mac
MacBook Pro 13" Retina (Late 2016-2019) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2019 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
来自US$49.99
MacBook Pro 13" Retina (A1708, A2159) Hinge Covers
Replace the plastic covers for the display hinges.
US$14.99
MacBook Pro 13" Retina (Late 2016-2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2020 model 13" MacBook Pro with Retina Display.
US$5.99
MacBook Pro 13" (A2159, 2019) Upper Case Assembly / A-Stock / Dark Gray
Replace an upper case, keyboard, and battery compatible with a 2019 model A2159 MacBook Pro 13 inch laptop with two Thunderbolt Ports.
US$399.99
MacBook Pro 13" (A2159, 2019) Lower Case / New / Dark Gray
Replace a lower case compatible with a 2019 model A2159 MacBook Pro 13 inch laptop with two Thunderbolt Ports.
US$149.99
MacBook Pro 13" (A2159, 2019) Touch Bar Cable Bracket / Used
Replace a bent or missing bracket that secures the touch bar cable in a 2019 model A2159 13" MacBook Pro with two Thunderbolt ports.
US$9.99
MacBook Pro 13" (A2159, 2019) Headphone Jack Cable Bracket / Used
Replace a bent or missing bracket that secures the headphone jack cable in a 2019 model A2159 13" MacBook Pro with two Thunderbolt ports.
US$7.99
MacBook Pro 13" (A2159, 2019) Touch ID Sensor Cable Bracket / Used
Replace a bent or missing bracket that secures the Touch ID sensor cable in a 2019 model A2159 13" MacBook Pro with two Thunderbolt ports.
US$7.99
MacBook Pro 13" (A2159, 2019) 1.4 GHz Logic Board with Paired Touch ID Sensor / 8 GB / 128 GB
Replace a damaged or malfunctioning 1.4 GHz Core i5 Motherboard. The Touch ID sensor is paired to the logic board and is included.
来自US$449.99
显示产品 1-9 / 9
电子设备简介
Released in July 2019, this 13" Macbook Pro features Quad-core Intel Core i5 1.4 GHz processors with Turbo Boost up to 3.9 GHz. Model A2159.
The most common repairs with the 13" 2019 model MacBook Pro 13" with Two Thunderbolt Ports laptops are replacing a dead battery or a damaged display assembly.
The battery is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2019 repair guides for step-by-step instructions on how to make the fix.
