配件 Mac MacBook Pro 13" Touch Bar Mid 2017 Hard Drives (SATA)
商店
不知道你的型号吗? 识别你的 Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7.99
MacBook Pro 13" Retina (Late 2016-2019) Display Assembly / A-Stock / Silver
The display assembly includes the Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, display daughter board, and cable spring mechanism. Compatib...
来自US$469.99
MacBook Pro 13" Retina (Late 2016-2019) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2019 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
来自US$49.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Battery / Fix Kit
Replace a dead or malfunctioning battery compatible with a MacBook Pro 13" Retina (Touch Bar, Late 2016/2017).
来自US$129.99
MacBook Pro 13"/15" Retina (Touch Bar, Late 2016-2017) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard.
US$149.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Display Cable / New
Replace the short flex cable that connects the display daughter board to the logic board.
来自US$19.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Power Button
Replace the sapphire faced Touch ID equipped power button assembly.
US$29.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
来自US$29.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case Screw Set / Silver
Replace the external screws securing the lower case.
US$19.99
显示产品 1-10 / 43
电子设备简介
Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz. Model A1706.
The most common repairs with the 13" 2017 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2017 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2017 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Touch Bar 2017 earned a 1 out of 10 in iFixit's repairability assessment.
