Fix Your Stuff
Right to Repair
Parts & Tools
Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Touch Bar Late 2016 Hard Drive Enclosures
商店
Grab a toolkit for your MacBook Pro 13" Touch Bar Late 2016 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
不知道你的型号吗? 识别你的 Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7.99
MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board / New
Replace one of the thunderbolt connector boards from the left or right side of your laptop.
来自US$29.99
MacBook Pro 13"/15" Retina (Touch Bar, Late 2016-2017) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard.
US$149.99
MacBook Pro Retina (Late 2016-Mid 2017) Plastic Feet
Replace missing or damaged black plastic feet on the lower case of your laptop.
US$4.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Battery / Fix Kit
Replace a dead or malfunctioning battery compatible with a MacBook Pro 13" Retina (Touch Bar, Late 2016/2017).
来自US$129.99
MacBook Pro 13" Retina (Late 2016-2017) Display Assembly / A-Stock / Silver
The display assembly includes the Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, display daughter board, and cable spring mechanism. Compatib...
来自US$469.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Headphone Jack / New / Black
Replace a damaged or corroded the 3.5 mm audio jack compatible with a 2016 or 2017 model 13" MacBook Pro with Retina Display and Touch Bar.
来自US$24.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Antenna Bar
Replace a damaged or malfunctioning antenna.
来自US$24.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
来自US$29.99
显示产品 1-10 / 45
电子设备简介
Released in November 2016 with the Apple model number A1706 / EMC 3071, this 13" Macbook Pro introduces the OLED Touch Bar, and features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
The most common repairs with the 13" Late 2016 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar Late 2016 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar Late 2016 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Touch Bar Late 2016 earned a 1 out of 10 in iFixit's repairability assessment. Watch the Teardown Review for more:
