Fix Your Stuff
Right to Repair
Parts & Tools
Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Touch Bar 2019 SSD Enclosures
商店
Grab a toolkit for your MacBook Pro 13" Touch Bar 2019 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
不知道你的型号吗? 识别你的 Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Antenna Bar
Replace a damaged or malfunctioning antenna.
来自US$24.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Right Small Speaker
Replace a damaged or malfunctioning high frequency tweeter speaker for the right side of a Late 2016 to 2019 MacBook Pro 13" with Touch Bar.
来自US$19.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Left Small Speaker
Replace a damaged or malfunctioning high frequency tweeter speaker.
来自US$19.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
来自US$29.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Display Cable Brackets
Replace the brackets that secure the display cable connector to the display daughter board and clamp the middle of the cable to the upper case assembly in a 2016 to 2019 ...
US$4.99
MacBook Pro 13" Retina (Mid 2018-2019) Display Cable
Replace the short flex cable that connects the display daughter board to the logic board.
US$24.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Right Fan / Used
Replace a defective or noisy fan compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
来自US$49.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Headphone Jack Bracket
Replace a bent or missing metal bracket that secures the headphone jack cable connector to the logic board in a 2016 to 2019 model 13" MacBook Pro with Retina Display and...
US$3.99
显示产品 1-10 / 31
电子设备简介
Introduced in May 2019, this 13" Macbook Pro features Coffee Lake processors up to 2.8 GHz Core i7 with Turbo Boost up to 4.7 GHz. Model A1989.
The most common repairs with the 13" 2019 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2019 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2019 repair guides for step-by-step instructions on how to make the fix.
