配件 Mac MacBook Pro 13" Retina Mid 2014 Hard Drives (SATA)
商店
Grab a MacBook Pro 13" Retina Mid 2014 Fix Kit and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
不知道你的型号吗? 识别你的 Mac
MacBook Pro Retina (A1425, A1502, and A1398) Plastic Feet / Part Only
Replace missing or damaged black plastic feet on your laptop's lower case.
来自US$4.99
MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery
Replacement 6330 mAh battery compatible with a MacBook Pro 13" Retina (Late 2013/Mid 2014) laptop.
来自US$99.99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7.99
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
来自US$149.99
MacBook Pro Retina (2012-2015) Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case.
来自US$19.99
MacBook Pro 13" Retina (Late 2013-Early 2015) Left Speaker
Replace a broken or damaged left speaker for your Late 2013 to Early 2015 MacBook Pro 13" Retina laptop with this part and fix sound issues.
US$27.99
MacBook Pro 13" Retina (Late 2013-Early 2015) Right Speaker
Replace a broken or damaged right speaker for your Late 2013 to Early 2015 MacBook Pro 13" Retina laptop with this part and fix sound issues.
US$29.99
MacBook Pro Retina (2012-2015) Display LVDS Cable
Replace a damaged connector or torn LVDS display cable.
US$19.99
MacBook Pro Retina (A1425, A1502, and A1398) Lower Case Screw and Foot Kit
Replace a missing or scuffed plastic foot or a missing screw securing the lower case of your laptop.
US$29.99
显示产品 1-10 / 36
电子设备简介
On July 29, 2014 Apple introduced a new 13" MacBook Pro with Retina Display. Externally, this "Mid 2014" model looks very much like the "Late 2013" model. The 13.3" widescreen 2560x1600 (227 ppi) display, external ports, and Wi-Fi capabilities are unchanged. The Mid 2014 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the Early 2013 and Late 2013 models, this machine has no Ethernet or Firewire ports, although adapters are available. Internally, the Mid 2014 model features faster processors and 8 or 16 GB of RAM that cannot be upgraded after purchase.
The most common repairs with the 13" Mid 2014 model MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina Mid 2014 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display Mid 2014 repair guides for step-by-step instructions on how to make the fix.
