修复你的物品
维修的权力
配件 & 工具
MacBook Air (Original) Fan and Heat Sink
  • MacBook Air (Original) Fan and Heat Sink
US$39.99
US$39.99
当产品有货时,我们将给你发送消息。
Manta 螺丝刀工具包
112 bits for every fix.
Upgrade Your Toolbox
Manta 螺丝刀工具包
产品详细说明
描述
描述
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your model A1237 MacBook Air to overheat and eventually damaging your processors. Replace a defective fan and heat sink to fix overheating problems or to keep your laptop running quietly.
零件包括
零件包括
  • Fan
  • Attached Heat Sink
兼容性
兼容性
  • 1.6 or 1.8 GHz Original MacBook Airs
产品规格
产品规格
Part #:
922-8316
安装视频
兼容性
MacBook Air Models A1237 and A1304
EMC 2142 1.6 GHz (Original)
EMC 2142 1.8 GHz (Original)
维修的故事
用户头像
我的问题
The fan was making a whistle noise... and the CPU was too hot for MBA to work normally.
我的修理方法
Changed the fan. Cleaned the inside of the laptop from dust…
我的建议
Clean the inside at least twice a year…
用户头像
我的问题
Existing fan was loud
我的修理方法
The repair went according to instructions. I like how all the different screws are identified. Made it really easy for reinstallation.
我的建议
Ifixit shows instructions on how to remove the fan from the heatsink but does not offer the option of buy the fan only. I had to buy the heatsink . . .
用户头像
我的问题
The machine began to run a little hot with excessive fan activity. Eventually no fan, just a faint clicking sound and rising temperatures, which I diagnosed from various blogs as fan failure.
I hadn't checked the heatsink vs processor temperatures so couldn't confirm the state of the heat sink / . . .
用户头像
我的问题
So, my original MacBook Air's fan started making a *horrible* very, un-Apple-like screeching sound. I added some lubrication and that helped a little, but in the end it appeared the fan unit itself had just worn out after working at thousands of RPMs for many hours thru the years.
我的修理方法
The repair took abo . . .
显示更多
