MacBook 13" Core Duo Case Components
Grab a toolkit for your MacBook 13" Core Duo model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Lower Case
Replace a scratched-up lower case
MacBook Memory Cover
Replace a bent or missing L-shaped metal cover for the RAM compartment in a MacBook laptop.
MacBook Left Dust Guard
Left Dust Guard
MacBook Right Dust Guard
Right Dust Guard
MacBook Santa Rosa/Penryn Upper Case with Keyboard
Replace an upper case, keyboard, trackpad, trackpad cable, and power button compatible with the MacBook model laptop. Part #922-9550, 922-8264, 922-8265, 661-5075, 661-50...
MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
LCD mount including airport antenna cables.
MacBook Rear Display Bezel
Replace a damaged bezel without the cost of a new LCD
MacBook Clutch Cover
Replace a damaged or missing clutch cover for a MacBook laptop.
MacBook Optical Drive Bezel
Replaces warped or broken optical drive bezel
MacBook Upper Case with Keyboard (Black)
Replace an upper case compatible with MacBook model laptops. Includes keyboard, palmrest area, trackpad, trackpad cable, and power button.
电子设备简介
The MacBook 13" Core Duo can be easily upgraded to a total of 2 GB of memory using two 1 GB RAM chips, and a 500 GB 7200 RPM SATA hard drive will give you plenty of storage. You can upgrade to the Santa Rosa/Penryn Upper Case, featuring a new keyboard layout (including iTunes controls)! The 8x SuperDrive is the fastest optical drive for this model and will make creating DVDs a whiz. Have you ever been caught sleeping while waiting for your file to transfer over slow wireless network? We can wipe away that unnecessary snooze-fest with the Airport Extreme 802.11n Card upgrade.
There is one main variation within this model. The heat sink thermal sensors may have three-wall or four-wall connectors. This affects the heat sink and logic board. See photos and part descriptions on the three-wall or four-wall heat sinks for information on determining which version you have.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
