跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
Why is my trackpad making a rattling noise after replacing battery?
Yesterday I replaced the old battery in my mac air and afterwards noticed that, whenever I touched the trackpad, it made a rattling noise. For some reason, it appeared that the trackpad had become loose.
So I did a little experiment: I took the new battery out and put my old battery in and the noise and the rattling disappeared.
So I'm pretty certain that it's the new battery that's causing the noise/rattle.
Any suggestions on what I should do? I actually tried putting a foam material between the battery and the trackpad to "push" the trackpad upwards, and the noise actually went away but it created another problem: the click function of the trackpad disappeared. I'm not sure how to solve both problems simultaneously.
Any ideas would be appreciated. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
2个答案
已选择的解决方案
Well, it's like this... Is the glass half full or half empty?
The reason the old battery stopped the noise is it has swelled up so it's pressing on the trackpad. The new battery is OK!
Because of the damage, the old battery caused your trackpad now has a bit of flex which can be fixed quite easily by carefully turning the adjustment screw. Review Step10 in this guide: MacBook Air 13" Mid 2013 Trackpad Replacement. That should fix it.
Update (04/23/2018)
@xcelr8t - When the original battery was installed day one it was the exact same size as your new battery.
But! Over time as the battery is used gases buildup inside and the battery expands. In some cases the battery will expand so much it will split the system apart! Here we have a slightly distorted uppercase which is why the trackpad is loose.
Here's a bulging battery in a MacBook Air:
This is the difference between two batteries:
这个答案有帮助吗?
得分 2
3条评论:
Thank you for taking the time to help me out.
However, I don't agree with your reasoning. When the old battery was completely new (when I first got the mac air), the rattling noise did not occur. So I don't think it's the swelling of my old battery that "blocked" the sound. Like I said, when that battery was completely new (aka not "swollen"), the rattling sound did NOT occur.
I think the rattling noise is happening because the structure of the old battery that came with the mac air is different from that of the new battery sent by ifixit.
完成的
Thank you for your reply. It is really helpful.
However, I still don't follow your explanation.
You said that, "Over time as the battery is used gases buildup inside and the battery expands."
Yet when I took out the old battery to replace with the new one, it was the same exact size (no expansion/swelling) as the new one. If indeed the old battery expanded during usage, I would have noticed it right away when I replaced it with the new battery, but I didn't. The old battery looked exactly the same as the new one, except for the different structure that touches the trackpad. The new one indents inwards while the old one didn't.
完成的
OK, I can't show you any better evidence than what I've shown you.
Place the batteries on a flat surface the old one will rock a bit. If that still doesn't prove it. Why don't you get a second new battery. If the second one is the same as the first replacement then you'll have the evidence there is something different between the old and the new. It doesn't take much pressure to bend things.
完成的
添加一条评论
so did it ever stop after you replaced the trackpad? I’m having the exact same issues as you are =\
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dan Chun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 21
总计 3,819
