跳转到主内容
why! WDi7SSD fan replacement
你所需要的
  1. why! WDi7SSD fan replacement, why! WDi7SSD Opening procedure: 步骤 1 中的图像 1,3 why! WDi7SSD fan replacement, why! WDi7SSD Opening procedure: 步骤 1 中的图像 2,3 why! WDi7SSD fan replacement, why! WDi7SSD Opening procedure: 步骤 1 中的图像 3,3
    • Make sure the computer is disconnected from the power source.
    • Flip the computer over.
    • Remove the six screws with a 2 mm Allen key.
    • Carefully remove the back panel, as well the left and right panel.
  2. why! WDi7SSD fan replacement: 步骤 2 中的图像 1,1
    • Now flip up the base panel to which all components are attached.
  3. why! WDi7SSD fan replacement, Fan: 步骤 3 中的图像 1,2 why! WDi7SSD fan replacement, Fan: 步骤 3 中的图像 2,2
    • Remove the two Phillips PH2 screws on the fan.
  4. why! WDi7SSD fan replacement: 步骤 4 中的图像 1,2 why! WDi7SSD fan replacement: 步骤 4 中的图像 2,2
    • Remove the cable connecting the front part (with the LEDs) to the power source.
    • Remove that part of the case and its cable.
  5. why! WDi7SSD fan replacement: 步骤 5 中的图像 1,3 why! WDi7SSD fan replacement: 步骤 5 中的图像 2,3 why! WDi7SSD fan replacement: 步骤 5 中的图像 3,3
    • Remove the four screws on the heat sink with a Phillips PH2 screwdriver.
    • Remove the heat sink.
  6. why! WDi7SSD fan replacement: 步骤 6 中的图像 1,2 why! WDi7SSD fan replacement: 步骤 6 中的图像 2,2
    • Carefully remove the fan together with its case.
    • Carefully remove the connector connecting the fan to the power source.
结论
In order to reassemble your device, follow the steps of this guide in reverse order.
由衷感谢以下译者:
de en
100%
Maria Parker正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
33,538 声望
创作了283篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 323
