简介
Describe what you will do.
你所需要的
Unlock the lock latch on the left.
Unlock the lock latch on the right.
Remove the battery while holding the lock latch unlocked.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
Lift the bottom right cover with the iFixit Opening Tool.
Lift the lower left cover with the iFixit Opening Tool.
Finally clear the bottom cover completely to access the main components.
Locate the RAM card in its slot.
Spread the leaf springs that hold the memory module in place (left and right).
Remove the memory module (RAM) from its connector.
To reassemble your device, Follow these instructions in reverse order.
由衷感谢以下译者:
100%
irlanda正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
