你所需要的
Unlock the lock latch on the left.
Unlock the lock latch on the right.
Remove the battery while holding the lock latch unlocked.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
Lift the bottom right cover with the iFixit Opening Tool.
Lift the lower left cover with the iFixit Opening Tool.
Finally clear the bottom cover completely to access the main components.
Once the bottom cover is removed you can start disassembling the keyboard.
Start by turning the computer over and then unscrew the screw shown in image 2 of this step.
Then using the screwdriver unscrew the bar that hides the screws fixing the keyboard.
To reassemble your device, Follow these instructions in reverse order.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
irlanda正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
