你所需要的
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
Now you can remove the bottom cover.
Using a Philips screwdriver #0, remove the screw securing the SSD.
Lift the end of the SSD slightly and pull it straight out to remove it.
即将完成!
结论
由衷感谢以下译者:
fr en
100%
Jerry W正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
