你所需要的
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
Working your way around the frame, unclip the mounting points of the frame surrounding the LCD screen.
Remove the two upper mounting screws securing the LCD to the lid.
Remove the two lower mounting screws.
Cover the keyboard with a cloth, then carefully lower the LCD screen onto the keyboard.
Using the plastic tab, peel back the tape securing the LCD cable the panel connector.
Unplug the connector.
The LCD screen can now be removed.
由衷感谢以下译者:
100%
Jerry Wheeler正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
