你所需要的
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
Now you can remove the bottom cover.
Press gently at the points indicated to release the LED cover strip.
Turn the laptop over, then lift the LED cover.
Remove the LED cover.
即将完成!
结论
由衷感谢以下译者:
fr en
100%
Jerry W正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
