你所需要的
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
Now you can remove the bottom cover.
Lift out the plastic tab (including the rubber part that holds the HDD in its slot).
Slide the drive to the left to disengage the connector then lift to remove the HDD from its SATA3 port.
即将完成!
结论
由衷感谢以下译者:
fr en
100%
Jerry W正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
