跳转到主内容
why! N240JU Replacement motherboard
你所需要的
  1. why! N240JU Replacement motherboard, Battery: 步骤 1 中的图像 1,2 why! N240JU Replacement motherboard, Battery: 步骤 1 中的图像 2,2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Replacement motherboard, Access to main components: 步骤 2 中的图像 1,2 why! N240JU Replacement motherboard, Access to main components: 步骤 2 中的图像 2,2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Replacement motherboard: 步骤 3 中的图像 1,3 why! N240JU Replacement motherboard: 步骤 3 中的图像 2,3 why! N240JU Replacement motherboard: 步骤 3 中的图像 3,3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Replacement motherboard, SSD M.2 disk: 步骤 4 中的图像 1,3 why! N240JU Replacement motherboard, SSD M.2 disk: 步骤 4 中的图像 2,3 why! N240JU Replacement motherboard, SSD M.2 disk: 步骤 4 中的图像 3,3
    • Locate the M.2 SSD in its slot.
    • Unscrew the fastening screw of the latter.
    • Lift and remove the SSD M.2 drive from its connector.
  5. why! N240JU Replacement motherboard, Hard disk (mass storage): 步骤 5 中的图像 1,3 why! N240JU Replacement motherboard, Hard disk (mass storage): 步骤 5 中的图像 2,3 why! N240JU Replacement motherboard, Hard disk (mass storage): 步骤 5 中的图像 3,3
    • Locate the hard drive in its location.
    • Lift it slightly.
    • Finally remove it from its SATA connector.
  6. why! N240JU Replacement motherboard, BIOS stack: 步骤 6 中的图像 1,2 why! N240JU Replacement motherboard, BIOS stack: 步骤 6 中的图像 2,2
    • To reassemble your device, follow the instructions in reverse order.
    • Lift it gently and take it out of its place.
  7. why! N240JU Replacement motherboard, WLAN card: 步骤 7 中的图像 1,2 why! N240JU Replacement motherboard, WLAN card: 步骤 7 中的图像 2,2
    • Carefully unplug the MAIN and AUX antennas.
    • Unscrew the fixing screw with the Philips # 0 screwdriver. Then lift the chipset slightly and remove it from the connector.
  8. why! N240JU Replacement motherboard, RAM Memory: 步骤 8 中的图像 1,3 why! N240JU Replacement motherboard, RAM Memory: 步骤 8 中的图像 2,3 why! N240JU Replacement motherboard, RAM Memory: 步骤 8 中的图像 3,3
    • Find and separate the spring blades that maintain the memory module in place (right).
    • Find and separate the spring blades that maintain the memory module in place (left).
    • Remove the memory module (RAM) from its connector.
  9. why! N240JU Replacement motherboard, The fan: 步骤 9 中的图像 1,3 why! N240JU Replacement motherboard, The fan: 步骤 9 中的图像 2,3 why! N240JU Replacement motherboard, The fan: 步骤 9 中的图像 3,3
    • Remove the power cable from the fan.
    • Unscrew the two screws securing the fan.
    • Finally remove the fan and place it on your worktop.
  10. why! N240JU Replacement motherboard, The keyboard: 步骤 10 中的图像 1,3 why! N240JU Replacement motherboard, The keyboard: 步骤 10 中的图像 2,3 why! N240JU Replacement motherboard, The keyboard: 步骤 10 中的图像 3,3
    • Unscrew the circled screws in green and red
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  11. why! N240JU Replacement motherboard: 步骤 11 中的图像 1,3 why! N240JU Replacement motherboard: 步骤 11 中的图像 2,3 why! N240JU Replacement motherboard: 步骤 11 中的图像 3,3
    • Disconnect the connector circled in red in the direction of the arrow
  12. why! N240JU Replacement motherboard, Motherboard: 步骤 12 中的图像 1,3 why! N240JU Replacement motherboard, Motherboard: 步骤 12 中的图像 2,3 why! N240JU Replacement motherboard, Motherboard: 步骤 12 中的图像 3,3
    • Locate the two flat cables and remove them carefully.
  13. why! N240JU Replacement motherboard: 步骤 13 中的图像 1,3 why! N240JU Replacement motherboard: 步骤 13 中的图像 2,3 why! N240JU Replacement motherboard: 步骤 13 中的图像 3,3
    • Locate the five connectors on the motherboard
    • Unplug all connectors
  14. why! N240JU Replacement motherboard: 步骤 14 中的图像 1,3 why! N240JU Replacement motherboard: 步骤 14 中的图像 2,3 why! N240JU Replacement motherboard: 步骤 14 中的图像 3,3
  15. why! N240JU Replacement motherboard: 步骤 15 中的图像 1,2 why! N240JU Replacement motherboard: 步骤 15 中的图像 2,2
    • Unscrew the four screws circled in red
    • Lift the motherboard by taking it through the radiator
  16. why! N240JU Replacement motherboard: 步骤 16 中的图像 1,3 why! N240JU Replacement motherboard: 步骤 16 中的图像 2,3 why! N240JU Replacement motherboard: 步骤 16 中的图像 3,3
    • Disconnect the two connectors circled in red
结论
另外一个人完成了本指南。
由衷感谢以下译者:
fr en
100%
irlanda正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
33,538 声望
创作了283篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 469
