跳转到主内容
why! N240BU Keyboard Replacement
你所需要的
  1. why! N240BU Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 why! N240BU Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240BU Keyboard Replacement, Access to main components: 步骤 2 中的图像 1,2 why! N240BU Keyboard Replacement, Access to main components: 步骤 2 中的图像 2,2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240BU Keyboard Replacement: 步骤 3 中的图像 1,3 why! N240BU Keyboard Replacement: 步骤 3 中的图像 2,3 why! N240BU Keyboard Replacement: 步骤 3 中的图像 3,3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240BU Keyboard Replacement, The keyboard: 步骤 4 中的图像 1,3 why! N240BU Keyboard Replacement, The keyboard: 步骤 4 中的图像 2,3 why! N240BU Keyboard Replacement, The keyboard: 步骤 4 中的图像 3,3
    • Unscrew the circled screws in green and red
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  5. why! N240BU Keyboard Replacement: 步骤 5 中的图像 1,3 why! N240BU Keyboard Replacement: 步骤 5 中的图像 2,3 why! N240BU Keyboard Replacement: 步骤 5 中的图像 3,3
    • Disconnect the connector circled in red in the direction of the arrow
结论
4等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
33,538 声望
创作了283篇指南
2指南评论
Thanks for the example. But where did you bought the keyboard? i can’t find it.
Marcos - 回复
Dear Sir,
thank you for your request. We are swiss keyboards, which you can order here:
''https://whyopencomputing.ch/fr/laptop-wh...
and we have a French AZERTY here:
''https://whyopencomputing.com/fr/laptop-w...
For other keyboards, please try by your local Clevo supplier.
Best regards.
Felice Suglia - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 496
