跳转到主内容
why! N240BU Fan replacement
你所需要的
  1. why! N240BU Fan replacement, Battery: 步骤 1 中的图像 1,2 why! N240BU Fan replacement, Battery: 步骤 1 中的图像 2,2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240BU Fan replacement, Access to main components: 步骤 2 中的图像 1,2 why! N240BU Fan replacement, Access to main components: 步骤 2 中的图像 2,2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240BU Fan replacement: 步骤 3 中的图像 1,3 why! N240BU Fan replacement: 步骤 3 中的图像 2,3 why! N240BU Fan replacement: 步骤 3 中的图像 3,3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240BU Fan replacement, Fan: 步骤 4 中的图像 1,2 why! N240BU Fan replacement, Fan: 步骤 4 中的图像 2,2
    • Remove the two screw circled in red
    • Disconnect the connector boxed in green in the direction of the green arrow
    • Remove the fan by lifting it up
结论
To reassemble your device, follow the instructions in reverse order
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
33,538 声望
创作了283篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 220
