跳转到主内容
why! N240BU CMOS Battery Replacement
你所需要的
  1. why! N240BU CMOS Battery Replacement, Battery: 步骤 1 中的图像 1,2 why! N240BU CMOS Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240BU CMOS Battery Replacement, Access to main components: 步骤 2 中的图像 1,2 why! N240BU CMOS Battery Replacement, Access to main components: 步骤 2 中的图像 2,2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240BU CMOS Battery Replacement: 步骤 3 中的图像 1,3 why! N240BU CMOS Battery Replacement: 步骤 3 中的图像 2,3 why! N240BU CMOS Battery Replacement: 步骤 3 中的图像 3,3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240BU CMOS Battery Replacement, CMOS Battery: 步骤 4 中的图像 1,2 why! N240BU CMOS Battery Replacement, CMOS Battery: 步骤 4 中的图像 2,2
    • Press with a screwdriver in the red circled area to spread the base of the battery
    • Remove the battery by holding the screwdriver down
结论
To reassemble your device follow the following instructions in reverse order
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
30,731 声望
创作了261篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 199
