跳转到主内容
why! N131WU/BU/ZU RAM Replacement
你所需要的
  1. why! N131WU/BU/ZU RAM Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: 步骤 2 中的图像 1,3 why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: 步骤 2 中的图像 2,3 why! N131WU/BU/ZU RAM Replacement, Remove the Keyboard: 步骤 2 中的图像 3,3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: 步骤 3 中的图像 1,3 why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: 步骤 3 中的图像 2,3 why! N131WU/BU/ZU RAM Replacement, Remove Keyboard Connections: 步骤 3 中的图像 3,3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU/BU/ZU RAM Replacement, Remove the upper screws: 步骤 4 中的图像 1,2 why! N131WU/BU/ZU RAM Replacement, Remove the upper screws: 步骤 4 中的图像 2,2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU/BU/ZU RAM Replacement, RAM (Memory): 步骤 5 中的图像 1,3 why! N131WU/BU/ZU RAM Replacement, RAM (Memory): 步骤 5 中的图像 2,3 why! N131WU/BU/ZU RAM Replacement, RAM (Memory): 步骤 5 中的图像 3,3
    • Gently pull outwards on the clips to free the RAM stick.
    • Remove the RAM Stick from its slot.
结论
To reassemble your device, follow the instructions in reverse order.
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Felice Suglia
于06/15/13注册
31,100 声望
创作了264篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 394
