你所需要的
Insert a small screwdriver into the holes the screws were removed from in the previous step to unclip the keyboard.
Using a plastic spudger, flip up the retaining latch on the ZIF connector securing the blue ribbon cable, then slide the cable straight out from the connector.
To release the orange flex cable, use the tip of a spudger to slide the latches on either side in the direction indicated by the arrows, then pull the cable straight out from the connector.
另外一个人完成了本指南。
由衷感谢以下译者:
77%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
