跳转到主内容
uAttend bn6000 Fingerprint Replacement
你所需要的
  1. uAttend bn6000 Fingerprint Replacement, Disassembly: 步骤 1 中的图像 1,1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Fingerprint Replacement: 步骤 2 中的图像 1,1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Fingerprint Replacement, Fingerprint: 步骤 3 中的图像 1,3 uAttend bn6000 Fingerprint Replacement, Fingerprint: 步骤 3 中的图像 2,3 uAttend bn6000 Fingerprint Replacement, Fingerprint: 步骤 3 中的图像 3,3
    • Remove the two 7mm PH #1 screws from the fingerprint scanner mounting tab by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    • Remove the fingerprint scanner assembly from the unit by lifting the scanner up and away from the unit housing.
  4. uAttend bn6000 Fingerprint Replacement: 步骤 4 中的图像 1,3 uAttend bn6000 Fingerprint Replacement: 步骤 4 中的图像 2,3 uAttend bn6000 Fingerprint Replacement: 步骤 4 中的图像 3,3
    • Disconnect the ZIF connector, by using your fingernail to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
结论
To reassemble , follow these instructions in reverse order.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 551
