跳转到主内容
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement
注:你正在编辑的一份前提条件指南。你所做的任何更改将影响包括此步骤的48指南
英语
韩语
正翻译步骤 21
步骤 21
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: 步骤 0 中的图像 1,3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: 步骤 0 中的图像 2,3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: 步骤 0 中的图像 3,3
  • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
  • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
  • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
  • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
  • Leave the pick in place before moving on.
在此插入翻译
在此插入翻译
在此插入翻译
在此插入翻译
在此插入翻译
您的所有投稿皆享有基于开源创作共享许可协议(CC BY-NC-SA)著作权利
