跳转到主内容
the Nokia 6230b Speaker Replacement
你所需要的
  1. the Nokia 6230b Speaker Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Press down the button on the back panel.
  2. the Nokia 6230b Speaker Replacement: 步骤 2 中的图像 1,2 the Nokia 6230b Speaker Replacement: 步骤 2 中的图像 2,2
    • Push the back cover upwards.
  3. the Nokia 6230b Speaker Replacement: 步骤 3 中的图像 1,2 the Nokia 6230b Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the back cover from the phone.
  4. the Nokia 6230b Speaker Replacement, Front Cover: 步骤 4 中的图像 1,1
    • Press the silver button on the top of the phone.
  5. the Nokia 6230b Speaker Replacement: 步骤 5 中的图像 1,1
    • Slide your thumbnail down the case seam to separate the rest of the case.
  6. the Nokia 6230b Speaker Replacement: 步骤 6 中的图像 1,1
    • Gently remove the case.
    • Careful! Do not bend the plastic tabs.
  7. the Nokia 6230b Speaker Replacement, Motherboard: 步骤 7 中的图像 1,2 the Nokia 6230b Speaker Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
  8. the Nokia 6230b Speaker Replacement: 步骤 8 中的图像 1,2 the Nokia 6230b Speaker Replacement: 步骤 8 中的图像 2,2
    • Remove the panel that covers the motherboard.
    • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
  9. the Nokia 6230b Speaker Replacement: 步骤 9 中的图像 1,1
    • Remove the LCD screen frame.
  10. the Nokia 6230b Speaker Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard.
  11. the Nokia 6230b Speaker Replacement, Speaker: 步骤 11 中的图像 1,1
    • Locate the speaker on the back of the removed panel.
  12. the Nokia 6230b Speaker Replacement: 步骤 12 中的图像 1,1
    • Use nails to gently lift the speaker up; speaker may be slightly glued to the panel.
  13. the Nokia 6230b Speaker Replacement: 步骤 13 中的图像 1,1
    • When the speaker is loose, gently lift the speaker out of the panel.
结论
Job Jao
于10/08/10注册
37 声望
创作了2篇指南
团队
Cal Poly, Team 3-27, Regan Fall 2010 Cal Poly, Team 3-27, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G27
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,758
