跳转到主内容
removing the HP Elitebook 6930p Optical Drive
你所需要的
  1. removing the HP Elitebook 6930p Optical Drive, Battery Removal: 步骤 1 中的图像 1,3 removing the HP Elitebook 6930p Optical Drive, Battery Removal: 步骤 1 中的图像 2,3 removing the HP Elitebook 6930p Optical Drive, Battery Removal: 步骤 1 中的图像 3,3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. removing the HP Elitebook 6930p Optical Drive, Optical Drive: 步骤 2 中的图像 1,3 removing the HP Elitebook 6930p Optical Drive, Optical Drive: 步骤 2 中的图像 2,3 removing the HP Elitebook 6930p Optical Drive, Optical Drive: 步骤 2 中的图像 3,3
    • With the bottom of the laptop facing up and the front toward you locate and loosen the M2.5×9.0 captive screw holding the optical drive into the laptop.
    • Insert a flat-bladed screwdriver or similar tool into the optical drive tab access hole and press the tab to the left to release the optical drive from the computer
    • The optical drive will unlock and pop out of the side of the laptop. You are now able to temove the optical drive from the laptop.
结论
7等其他人完成本指南。
Richdave
于04/09/10注册
32,063 声望
创作了30篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,532篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 4,120
