跳转到主内容
removing the Dell Inspiron 1150 Speakers
你所需要的
  1. removing the Dell Inspiron 1150 Speakers, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 1,3 removing the Dell Inspiron 1150 Speakers, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 2,3 removing the Dell Inspiron 1150 Speakers, Removing Dell Inspiron 1150 Battery: 步骤 1 中的图像 3,3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. removing the Dell Inspiron 1150 Speakers, Hard Drive: 步骤 2 中的图像 1,2 removing the Dell Inspiron 1150 Speakers, Hard Drive: 步骤 2 中的图像 2,2
    • Place laptop upside down on a clean flat surface.
    • Remove 2ea M2.5 x 5 mm screws.
    • Pull the HDD from main body of the laptop.
  3. removing the Dell Inspiron 1150 Speakers, Optical Drive (Based on Dell Service Manual): 步骤 3 中的图像 1,3 removing the Dell Inspiron 1150 Speakers, Optical Drive (Based on Dell Service Manual): 步骤 3 中的图像 2,3 removing the Dell Inspiron 1150 Speakers, Optical Drive (Based on Dell Service Manual): 步骤 3 中的图像 3,3
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
  4. removing the Dell Inspiron 1150 Speakers, Keyboard: 步骤 4 中的图像 1,3 removing the Dell Inspiron 1150 Speakers, Keyboard: 步骤 4 中的图像 2,3 removing the Dell Inspiron 1150 Speakers, Keyboard: 步骤 4 中的图像 3,3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  5. removing the Dell Inspiron 1150 Speakers: 步骤 5 中的图像 1,3 removing the Dell Inspiron 1150 Speakers: 步骤 5 中的图像 2,3 removing the Dell Inspiron 1150 Speakers: 步骤 5 中的图像 3,3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
  6. removing the Dell Inspiron 1150 Speakers, Display Assembly: 步骤 6 中的图像 1,3 removing the Dell Inspiron 1150 Speakers, Display Assembly: 步骤 6 中的图像 2,3 removing the Dell Inspiron 1150 Speakers, Display Assembly: 步骤 6 中的图像 3,3
    • Remove 1ea M2.5 x 8mm screw holding the EMI shield in place
    • Remove the EMI shield to expose the LCD ribbon cable
    • Gently pull up on the tab to disconnect the ribbon cable from the main board
    • Close the lid carefully and remove the two M2.5 x 5-mm screws from the rear of the case
  7. removing the Dell Inspiron 1150 Speakers: 步骤 7 中的图像 1,3 removing the Dell Inspiron 1150 Speakers: 步骤 7 中的图像 2,3 removing the Dell Inspiron 1150 Speakers: 步骤 7 中的图像 3,3
    • Open the lid and support the Display Assembly while performing the next step to avoid it falling down when the hinge screws are removed
    • Remove 2e M2.5 x 5mm screws from each hinge bracket
    • The Display Assembly can now be lifted free of the laptop body
  8. removing the Dell Inspiron 1150 Speakers, Removing Dell Inspiron 1150 Palm Rest: 步骤 8 中的图像 1,2 removing the Dell Inspiron 1150 Speakers, Removing Dell Inspiron 1150 Palm Rest: 步骤 8 中的图像 2,2
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  9. removing the Dell Inspiron 1150 Speakers: 步骤 9 中的图像 1,2 removing the Dell Inspiron 1150 Speakers: 步骤 9 中的图像 2,2
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
  10. removing the Dell Inspiron 1150 Speakers, removing the Dell Inspiron 1150 Speakers: 步骤 10 中的图像 1,3 removing the Dell Inspiron 1150 Speakers, removing the Dell Inspiron 1150 Speakers: 步骤 10 中的图像 2,3 removing the Dell Inspiron 1150 Speakers, removing the Dell Inspiron 1150 Speakers: 步骤 10 中的图像 3,3
    • The speakers are located along the front of the laptop.
    • Disconnect the speaker cables from the main board
    • Unclip the speaker cables from the wire retainers along the front
    • Remove the speakers by pulling them straight up and out of the base
结论
Lauren
于04/25/10注册
4 声望
创作了2篇指南
团队
Cal Poly, Team 16-2, Maness Spring 2010 Cal Poly, Team 16-2, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G2
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 3,147
