简介
Step by step instructions on replacing your Nikon S3700 Lens
你所需要的
Remove Rear casing.
With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
Flip over rear buttons board to expose LCD ZIF clamp.
Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
Remove the LCD.
Discharge the capacitor to avoid getting shocked.
Dislodge clamps on all 4 sides and remove rear metal plate.
Release lens & CCD flex from ZIF sockets by gently lifting the black locking bar at the rear of the sockets. These may be a little stiff so care is needed.
Remove lens from housing and replace. Reverse steps for re-assembly
Area highlighted in orange can be lost easily. Please keep your eyes on this part. If unit is tilted part will fall out.
