跳转到主内容
nikon s3700 LCD Display Screen Replacement
你所需要的
  1. nikon s3700 LCD Display Screen Replacement, Removing the Screws: 步骤 1 中的图像 1,3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: 步骤 1 中的图像 2,3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: 步骤 1 中的图像 3,3
    • group screws according to color code.
    • Remove exterior screws
  2. nikon s3700 LCD Display Screen Replacement, Replace LCD: 步骤 2 中的图像 1,3 nikon s3700 LCD Display Screen Replacement, Replace LCD: 步骤 2 中的图像 2,3 nikon s3700 LCD Display Screen Replacement, Replace LCD: 步骤 2 中的图像 3,3
    • Remove Rear casing.
    • With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
    • Flip over rear buttons board to expose LCD ZIF clamp.
    • Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
    • The ZIF clamp is very fragile so please use caution when releasing the ZIF clamp. It breaks easily.
    • Remove the LCD.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 12
过去 30 天: 20
总计 662
