跳转到主内容
加入维修社区 - 创建账户
ionvac SmartClean V2 Shell (Top & Bottom) Replacement
你所需要的
  1. ionvac SmartClean V2 Shell (Top & Bottom) Replacement, Shell (Top & Bottom): 步骤 1 中的图像 1,2 ionvac SmartClean V2 Shell (Top & Bottom) Replacement, Shell (Top & Bottom): 步骤 1 中的图像 2,2
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 步骤 2 中的图像 1,3 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 步骤 2 中的图像 2,3 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 步骤 3 中的图像 1,1
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 步骤 4 中的图像 1,2 ionvac SmartClean V2 Shell (Top & Bottom) Replacement: 步骤 4 中的图像 2,2
    • Lift the top shell off carefully.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 17
总计 232
