简介
Swivel wheels rotate 360 degrees and are designed to help your ionvac SmartClean V2 turn corners or change directions smoothly. Because of its swivel caster (or a wheel that is assembled with a rotating mount, much like the wheels on a shopping cart), these types of wheels can swivel while under a load. They are often sold as a universal wheel for robot vacuums and other machines to improve their efficiency. If your ionvac does not turn like it should, this may be a sign that the swivel wheel needs to be cleaned or replaced. Check out this video (for a Roomba, not an ionvac) for further instructions on cleaning a universal wheel, and why doing so improves performance.
This is a quick and easy replacement, and you will not need any tools to complete it. Remember to remove and reinstall all parts gently.
