跳转到主内容
ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement
  1. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement, Front Wheel (Swivel Caster): 步骤 1 中的图像 1,1
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Flip your ionvac upside down so the wheels are pointed upwards.
  2. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: 步骤 2 中的图像 1,2 ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: 步骤 2 中的图像 2,2
    • Using your thumb and forefinger, grip the flat sides of the wheel and pull it out.
    • If the wheel is stuck, you can use a spudger to pry the caster out.
    • When reinstalling, the wheel should click into place. Before restarting the ionvac, try spinning the wheel with your finger to test its movement.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 69
