跳转到主内容
加入维修社区 - 创建账户
iView-776TPCII Rear Panel Replacement
你所需要的
  1. iView-776TPCII Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 1,3 iView-776TPCII Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 2,3 iView-776TPCII Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
    询问修复机器人
    添加评论
  2. iView-776TPCII Rear Panel Replacement: 步骤 2 中的图像 1,2 iView-776TPCII Rear Panel Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
IUPUI, Team 2-2, Baechle Fall 2015 IUPUI, Team 2-2, Baechle Fall 2015 的会员
IUPUI-BAECHLE-F15S2G2
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 49
总计 719
