跳转到主内容
iVIEW-754TPC Rear Panel Replacement
你所需要的
  1. iVIEW-754TPC Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 1,3 iVIEW-754TPC Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 2,3 iVIEW-754TPC Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
结论
Robert Clark
于01/21/15注册
1,065 声望
创作了7篇指南
团队
USF Tampa, Team 5-4, Brown Winter 2015 USF Tampa, Team 5-4, Brown Winter 2015 的会员
USFT-BROWN-W15S5G4
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 224
