跳转到主内容
iVIEW-754TPC Battery Replacement
你所需要的
  1. iVIEW-754TPC Battery Replacement, Rear Panel: 步骤 1 中的图像 1,3 iVIEW-754TPC Battery Replacement, Rear Panel: 步骤 1 中的图像 2,3 iVIEW-754TPC Battery Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC Battery Replacement, Remove Battery: 步骤 2 中的图像 1,3 iVIEW-754TPC Battery Replacement, Remove Battery: 步骤 2 中的图像 2,3 iVIEW-754TPC Battery Replacement, Remove Battery: 步骤 2 中的图像 3,3
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  3. iVIEW-754TPC Battery Replacement, Desolder wires: 步骤 3 中的图像 1,3 iVIEW-754TPC Battery Replacement, Desolder wires: 步骤 3 中的图像 2,3 iVIEW-754TPC Battery Replacement, Desolder wires: 步骤 3 中的图像 3,3
    • Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
    • Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
    • To ease reassembly, take note of which wire goes to the negative and positive terminals.
结论
3等其他人完成本指南。
calvin
于01/21/15注册
188 声望
撰写一个指南
团队
USF Tampa, Team 5-4, Brown Winter 2015 USF Tampa, Team 5-4, Brown Winter 2015 的会员
USFT-BROWN-W15S5G4
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 12
总计 2,546
