跳转到主内容
iRobot looj 120 Rear Motor Replacement
你所需要的
  1. iRobot looj 120 Rear Motor Replacement, Rear Motor: 步骤 1 中的图像 1,1
    • Remove the four exterior screws
结论
Joshua
于10/24/14注册
631 声望
创作了6篇指南
团队
UMass Dartmouth, Team 2-5, Duarte Fall 2014 UMass Dartmouth, Team 2-5, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G5
3 名成员
创作了7篇指南
1指南评论
Yeah, to replace the motor just 4 screws and no parts required! Too easy, too easy to write an article that doesn’t help :( Is it just to sell a screwdriver? This would not improve your reputation. You’re wasting our time and wasting your time.
Description: Remove the 4 screws than anyone can see is a good start but did anyone been able to actualy open the body and access inside the box?
I do have an iRobot Looj 330. The body looks very similar to the other model in the range. There are 4 screws, yes but the body in 2 parts doesn’t open that easy. It’s waterproof, I believe there is a trick… Which?
Daniel B - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 371
